vapormma
Добавлено: Tue Mar 16, 2021 3:01 pm Заголовок сообщения: Best partner for your planting business |
Are you looking greenhouse grow lights?
Are you worried about not finding the right f full spectrum led grow light?
Don`t worry ! Today I will introduce you best commercial led grow lights and the powerful led grow light !
1.ECO Farm 630W CMH Hydroponic Ceramic Metal Grow Light For Greenhouse
HIGH-QUALITY BALLAST: Electronic Ballast 120-240V with advanced low-frequency technology, designed specifically for CMH 315W Grow Light, high efficiency, reliability, and no electromagnetic interference
HIGH REFLECTIVITY RATING: Sturdy reflective hood is made of German aluminum rated at 95% reflectivity, maximizes the light to the plants with excellent color rendering and outstanding high quality
FULL SPECTRUM LIGHT: This fixture includes a high-quality CMH/CDM 315W 3100K bulb 15000hours lifetime, delivers a more efficient spectrum for growing;
QUALITY WARRANTY: ETL Certified to ensure the Fixture has 3 years warranty, The CMH315W/3100K Bulb has 1-year warranty.
2. ECO Farm 450W CXB3590 COB Full Spectrum LED Grow Light
Unique Design:150W COB, high power replace 600-800w HPS
Full spectrum led grow light: 380nm-850nm .UV-IR .All Useful Wavelength Include for All Phases of Plant Growth.
Modular Design: Easy for Assemble and Disassemble.
Energy Saving: Dimmable Design Make Sure No Need Full Power Used!
Biggest Footprint: 5*3 feet. Suitable for at Least 4-6 Plants!
Self-protection: Lights Will Turn off Actively for Self-protection if the Temp is Too Hot.
3.New SF1000D Series Full Spectrum 100W LED Grow Light
BETTER LIGHT PENETRATION: SF1000D used SAMSUNG Diodes-the highest light output LED available at present, delivers powerful light output and uniform canopy penetration to resulting maximum higher yields compared with other Led grow lights.
LOWER RUNNING COSTS:
High Energy Efficiency with 2.6 umol/J. Consuming only 100W, achieve better or comparable results than 200 watts HID with 50% less heat and power consumption. Perfect for 2?x2? coverage.
SUNLIGHT SPECTRUM: Full spectrum 660-665nm,3000K,5000K and IR, ideal for all growth stages (germination, clones or cuttings, mothers, vegetative, and flowering applications), turn your seeds into your own supply, produce beautiful high yielding plants.
There are something new arrival ! May be you can find something fit yourself.
ECO Farm 660W/760W/900W LED Light Strips
1. Use Samsung high bin LEDs, ultra high PPFD, replace HPS 600W and 1000W perfectly
2. 660W /900W/ multiple wattage optional
3. High lighting effect, 90% led grow light will be absorbed by plant, but to the tradition HPS light and MH light, its effect only 8% - 10%.
4. LED MODEL Meteor Storm is a high performance & affordable top-lighting solution for horticulture. Designed for applications requiring efficient,precise and uniform levels of PPFD.
If you want to know more discount information, please visit the official website ECO Farm led |
