Добавлено: Wed Sep 22, 2021 8:13 am Заголовок сообщения: Wholesale Activity Of LED Grow Lights at 24% In 2021!
Today, many growers love to use LED grow lights for hydroponics system. So I want to tell you a good news, eco farm grow lighteco farm grow light is at big discount!
ECO Farm 100W/220W/460W/660W Samsung Quantum BoardSamsung Quantum Board With LM281B Chips +UV+IR LED Grow Light
Description:
1. Shorten growth cycles
2. Improve color, shape and taste
3. Plant growth is not affected by the weather
4. Custom light recipe to fit your crop & situation
5. Best for all plants all stages growing
6. Increase yield & crоp quality
7. Low maintenance costs
8. Easy to mount and connect
ECO Farm 200W/400W/600W Dimmable Samsung LED Grow LightsSamsung LED Grow Lights With 301B +Osram 660NM Chips Meanwell Driver
Description:
ECO Farm grow light came with Samsung LM301B LEDs, higher light intensity, less light decay, better lumens and PAR values than ordinary lamp beads. It runs at a lower temperature and can bring higher energy conversion and longer life. This grows light is a full-cycle lighting solution for all growing environments including wet situations and is ideal for greenhouse supplemental lighting or indoor sole-source lighting. Full Spectrum 301B White Light + Osram 660nm Plant Red Light.
No fans no noise and waterproof function. Lots of heat sinks and hollow body ensures maximum heat dissipation. No additional fan zero noise. Otherwise, the plant grows light uses an advanced waterproof power supply which is installed outside of the light and it is easy to be replaced. The light board adopts sealing technology, so the whole plant grow light can reach IP44 water-resistant level. No need to worry about the humid planting environment to damage the plants lightly.
If you are also interested in diy led grow lightdiy led grow light. Welcome to visit our official website: ecofarm.caecofarm.ca.
