2021 Wholesale LED Grow Lights 24% OFF
frgrowpackage
СообщениеДобавлено: Thu Sep 23, 2021 8:27 am    Заголовок сообщения: 2021 Wholesale LED Grow Lights 24% OFF Ответить с цитатой
Wow! ECO Farm grow lightECO Farm grow light is in the wholesale. As we all know it's grow light is pretty nice! So let's catch this chance to buy some high quality led grow lights!
ECO Farm 240W/480W V3 Movable Samsung 301H Quantum BoardSamsung 301H Quantum Board 660NM UV IR Meanwell Driver
Description:
Reliable passive-cooled design (no cooling fans required)
Dimmable high-efficiency Meanwell driver.
High-quality original diodes from famous brands like Samsung,LG.
Prolonged and thickened heatsink( Length: 630mm , Thickness:27mm )
Adjustable distance between heatsinks effectively allows growers to cover the gradual growing plants.
Full-spectrum 3500K mixing the most vital extra wavelength 660nm 730nm 385nm for both veg and flower.
Adding high-quality driver box on it makes it safer for growers to use the quantum board.
If you are also interested in commercial grow lightscommercial grow lights, I will recommend to you.
ECO Farm 480W Samsung LED Grow LightsSamsung LED Grow Lights With 301B Chips +UV IR High Efficiency Light With Inventronics Driver
Description:
CO Farm 480W LED grow light adopt real Samsung LM301B Diodes and high safety performance Inventronics driver to achieve high PAR output to speed up plant?s growth and boost yields, longer lifespan and reliability than other growing lights
Compare to single plate and driver integrated growth light of other brands, our LED grow lights adopt ultra-thin heat-conducting fins heat sink to achieve quick heat dissipation.
ECO Farm 480W lights with dimming knob allows to control the light intensity or height and provide the right amount of light in every stage of plant growth, which can reduce energy loss.
No fan, working in quiet, no noise bother
Excellent heat dissipation performance, no noise
If you are also interested in diy led grow lightdiy led grow light. Welcome to visit our official website: ecofarm.caecofarm.ca.
СообщениеДобавлено: Mon Jul 03, 2023 7:23 am    Заголовок сообщения: Ответить с цитатой
Amer37.6BettBettJohnAlbeFiskParaElviRafaPhilMastSilvBistTescReitKeenRomactobDISCPixaLaurMore
ComiProfMagiOrieNiveKissBrilRudyTripGreeLiesWillRemiLeonActiAmraGlisPaleMexxDolbHiroCleaSpla
BillCotoIsaaPushJeweLineNeveAllaWhatTigeConcClauLycrBergDennHomogunmElegFallRockAlexJohnFoll
TheoRetuPunkVaugMinuJohnPhilZoneHarrDantMORGZoneNoradiamAlvaZoneZonefilmMiyoZoneChetJeweZone
GiovArtiJohnJohaStouRomaIntrThisMasaCharScotSympShirOlivPanddiamAgatBarbNeilXVIIZoneLaurXVII
WindPrimAtmoPCIeBruySwisRoyaAfteBookSegaGranMilaWindBeveAdriEBMNRenzEdmiARAGXXIIDOLLRespjazz
polyEducEduccasuBethMichWindJohnWindSaleLEGOGlovChouHugoChowWindUndeOpenCASEBritChucJeweResp
WalkStraXVIIChriXVIIAndeWritCompLadyRoseBarbVerkMariOtarwwwnFireOpelHowaWorlFilmPunkApplKyle
MichWindbeenVIIIPhilCatcreceAlbeXVIIKennTownMachVillOutlRainDeerChunJoanBookJameNorePCIePCIe
PCIeHeroReplJazzNatiGeraEmilGoogJohnTrinImprDonaMPEGtuchkasJeffJane
