Best selling! hannya airtok!
dysdylcom
СообщениеДобавлено: Fri Nov 11, 2022 3:37 pm    Заголовок сообщения: Best selling! hannya airtok! Ответить с цитатой
Hi, guys! today I will introduce you to a product with a relatively high search volume on our website recently: hannya airtok. This product has been widely favored by consumers as soon as it was launched. Orders include "Elf Bar", "Yumi Bar", "Drala" these 3 brands of products, as long as more than 50 euros, an extra free yumi bar 900 (any flavor). Date: 9th ? 13th Nov, 2022.
Details:
Vapelustion hannya airtok vape Kit is a pod system with trend style and good vaping flavor, it is suitable as an entry-level pod system for new vapers. Equipped with 650mAh battery and 1.0ohm mesh coil, it will bring longer battery life and better taste. The pod comes with the design of dual airflow for MTL and DTL vape. Inspired by rechargeable lighters, the familiar body style is designed with stylish anime colors. With built-in coil design, there are no needs to worry about leakage. What's more, hannya airtok buy can resist falling and minimize wear. The pop-up snap cover design makes it keep clean, and solves the hygiene problem from a deep level. A polyester lanyard is included.
Main Features:
1. An entry-level pod system for new vapers
2. Translucent frosted texture
3. Anti-dust, color hunt from inside
4. Metal buckle open cover design
5. 650mAh battery, clear view pod
6. LED indicator, type-c fast charging
7. 1.0ohm mesh coil
8. Dual airflow design: for MTL and DTL
9. Anti-leakage technology
10. Magnetic pod design
11. Comes with lanyard loop and silicone lanyard
You may also like:
hannya 2
hannya nano
