Добавлено: Tue Nov 29, 2022 1:41 pm Заголовок сообщения: uwell caliburn a2 VS uwell caliburn a2s Comparation
Today, I will show you two very similar electronic cigarette products: uwell caliburn a2 and uwell caliburn a2s. These two products are very similar in appearance, and many customers cannot tell them apart. Today, I will show you the difference in detail. BUY 1 GET 2(The color of the gift will be sent randomly, and it will be added in the package.) 7% Off Sitewide. (No coupon code required, total discount amount can be found at your shopping cart.) . Date: 21st ? 30th Nov, 2022. Best Vape for on the go and for every occasion! 100% Satisfaction Guarantee! We deliver duty and VAT free!
Details:
Uwell Caliburn A2 Kit adopts ultra-light materials with unique ergonomic design for better grip. The exclusive PRO-FOCS tech of Uwell would bring you the most authentic flavor. With an internal 520mAh battery, Caliburn A2 delivers effortless, all-day vaping on the go. Each kit comes complete with two Caliburn A2 refillable pods that feature mesh coils for better flavor. This kit has a lightweight frame and slim design, very easy to carry. It also has 6 Different Colors for you to choose from. Its maximum wattage output can be up to 15W. The battery only takes 35mins to 90% charged with Type-C. Uwell Caliburn A2 Pod comes with 2ml e-juice capacity, it features top filling system to prevent leakage. The perfect lip fitting design and magnetic suction give you a better vaping experience. Caliburn A2 Pod adopts FeCrAI UN2 Meshed-H 0.9 Ω coil to deliver excellent flavor and dense clouds.
Details:
Caliburn A2S Kit, Featuring 2ml e-lquid capacity, 1.2ohm Caliburn A2 Side Refilling Pod, 520 mAh battery, and 15 W output power, Caliburn A2S is a compact pod system with simplicity. Caliburn A2S comes in a lights-consisted logo, a refillable pod, and a Type-C port. The device is compatible with the 0.9ohm Caliburn A2 refillable pod.
Package Includes:
1* Caliburn A2S Device
1* FeCrAI UN2 Meshed-H 1.2ohm Caliburn A2 Side Refillable Pod (Pre-installed)
1* FeCrAI UN2 Meshed-H 1.2ohm Caliburn A2 Side Refillable Pod (Spare)
1* User Manual
